Instalacja biblioteki modbus
: 08 mar 2010 17:39
Witam mam pytanie jak zainstalować taką bibliotekę w labview 2009. Do dam że nigdy takiego czegoś nie robiłem
Pozdrawiam.
Pozdrawiam.
Polskie źródło wiedzy o środowisku programowania LabVIEW
https://www.labview.pl.h5990957.hostingrd.pl/
https://www.labview.pl.h5990957.hostingrd.pl/viewtopic.php?t=2811
Do LabVIEW 2009 skopiuj wersję z LabVIEW 8.6Installing NI-MODBUS Library
In order to use the Library in LabVIEW, please follow these steps:
Close LabVIEW.
If you have version NI-MODBUS Library 1.1 on your system, it is recommended to uninstall it by going to Control Panel -> Add Remove Programs -> National Instruments Software and select NI Modbus 1.1 from the list.
Copy NI Modbus.llb from the ##\vi.lib folder to the LabVIEW_ROOT\vi.lib directory where ## is your LabVIEW version (example 86 for 8.6) and is the root folder where you installed LabVIEW.
Copy lvmodbus.chm and lvmodbus.txt from ##\help to the LabVIEW_ROOT\help directory.
Copy nimodbus.mnu from ##\user.lib to the LabVIEW_ROOT\user.lib directory.
Restart LabVIEW. You should see the NI Modbus palette in the User Libraries palette.
To Uninstall the Library, remove all the files copied from the previous steps.
